Group: DynoMotion Message: 2639 From: bradodarb Date: 12/7/2011
Subject: Master Homing Program
Hello Tom,
What is the best way to detect encoder edges while homing?
I wanted to offer methods for rising and falling.
Thank you,
Brad Murry
Group: DynoMotion Message: 2640 From: Tom Kerekes Date: 12/7/2011
Subject: Re: Master Homing Program
Hi Brad,
Not sure what you mean as I'm sure you know this but:
int Polarity= 1;  /// set to 1 to wait for a rising edge or 0 to wait for a falling edge
while (ReadBit(xx) != Polarity) ;   // wait for the desired polarity level
Group: DynoMotion Message: 2641 From: Brad Murry Date: 12/7/2011
It’s just not natural for me that kflop/kanalog/snapamps handles encoders on it’s GPIO.  I’m used to using separate methods for encoders on other controllers because most devices the IO is not fast enough.
I wasn’t sure if there were secret methods for it.
-Brad
Sent: Wednesday, December 07, 2011 3:35 PM
Subject: Re: [DynoMotion] Master Homing Program
Hi Brad,
Sent: Wednesday, December 7, 2011 2:29 PM
Subject: [DynoMotion] Master Homing Program
Hello Tom,
Thank you,
Brad Murry
Group: DynoMotion Message: 2642 From: himykabibble Date: 12/7/2011
Brad,
"I wasn't sure if there were secret methods for it." - Even if there are, he won't be able to tell you - they're SECRET!!! :-)
Ray L.
> -Brad
> Hi Brad,
> Hello Tom,
> Thank you,
> Brad Murry
Group: DynoMotion Message: 2643 From: bradodarb Date: 12/7/2011
haha
Well he did try to keep "GetStopState" under wraps, so you just never know.
Then there is the top secret KStep device that is camouflaged as a Kanalog.
Makes you wonder whats really going on....
-Brad
> Brad,
> Regards,
> Ray L.
> > -Brad
> > Hi Brad,
> > Hello Tom,
> > Thank you,
> > Brad Murry
Group: DynoMotion Message: 2704 From: dynomotosaurus Date: 12/12/2011
KStep? Camouflaged Links? [waves hand] "These are not the Boards you are
looking for..."
Regarding the Edge detection, isn't the while loop just looking for the
configured input to be in the desired On/Off State? Meaning any time
that code runs (regardless of edge transition) if the input is in the
desired state the while loop will pass though to the next line even if
it is still active from the previous while loop test.
I did something similar in a different device (Machine Vision Smart
Camera [PPT Impact]) where I needed to detect rising edge and falling
edge transitions on regular boolean values set over Modbus (regular
inputs had RE and FE event triggers, but Modbus Registers do not), I
wanted a single output that was true for one execution pass but false on
subsequent passes if the monitored input transitioned from false to
true, and remained true. All I did was to replicate the functionality
of the IEC 61131-3 R_Trig and F_Trig functions (which I use daily on PLC
and other Motioncontroller systems we work with here).
Basically you need an Input [Clk] (physical , or boolean variable) you
want to monitor, an output [Q] (physical, or boolean variable), and a
temporary boolean [LastClk] variable that can remember the previous
Input state.
R_Trig works like so...
Q=Clk & (!LastClk);
LastClk=Clk;
F_Trig...
Q=LastClk & (!Clk);
LastClk=Clk;
Granted the code as presented would require unique named Q/Clk/LastClk
for each different Input and output state, but could be easily converted
to function call where you pass the input/bool the desired index you
want it assigned to, and a reference to an array of structures (if you
want to maintain RE/FE states for multiple inputs). The array structure
index would be used to reference the Q output for one shot execution in
a flow control block (if/while, etc).
Best Regards,
Patrick
> haha
know.
Kanalog.
> -Brad
> --- In DynoMotion@yahoogroups.com, "himykabibble" jagboy@ wrote:
> > Brad,
> > Regards,
> > Ray L.
not fast enough.
> > > -Brad
> > > Hi Brad,
level
> > > Regards
> > > Hello Tom,
> > > Thank you,
> > > Brad Murry
Group: DynoMotion Message: 2730 From: bradodarb Date: 12/18/2011
Hello Patrick,
I must have missed this one, sorry for the delayed response.
Kstep eh? Not the boards I' looking for? Very nice, it seems Dyno is going after the hobbyist stepper market with 'force'...
Actually with real closed loop steppers(instead of fault on position error limit only) I'd wager a stepper system + kflop is certainly not just for the hobby shop.
On the R/F::
So I think I understand what you are saying...
1 check initial state
2 if already at desired state, move until state changes
3 wait for desired state
Is that about right?
This way we would be more near the begining of the desired state instead of some random position in between states?
-Brad Murry
> looking for..."
> Input state.
> Q=Clk & (!LastClk);
> LastClk=Clk;
> F_Trig...
> Q=LastClk & (!Clk);
> LastClk=Clk;
> Best Regards,
> Patrick
> > haha
> know.
> Kanalog.
> > -Brad
> > > Brad,
> > > Regards,
> > > Ray L.
> not fast enough.
> > > > -Brad
> > > > Hi Brad,
> level
> > > > Regards
> > > > TK
> > > > Hello Tom,
> > > > Thank you,
> > > > Brad Murry
